Google BigQuery Reading Failure
  • Apr 15, 2019 3:47 PM UTC
  • 92 views
FME 2019.0 build 19238 Desktop on Windows 10 and Server on Linux (CentOS 7)
I'm trying to migrate a large dataset (tens millions records) from a Google BigQuery table into a PostgreSQL table, but the translation failed and this error was logged. Tried some times, the translation stops always with the same error.
Translation FAILED with 1 error(s) and 0 warning(s) (11375000 feature(s) output)
FME Session Duration: 59 minutes 9.9 seconds. (CPU: 1945.4s user, 53.5s system)
END - ProcessID: 11848, peak process memory usage: 1027252 kB, current process memory usage: 843964 kB
java.lang.Exception: Google BigQuery: Error retrieving query results from job '****************:********.********' executed on table job_*_***************. Provider error: 401 Unauthorized
  "code" : 401,
  "errors" : [ {
    "domain" : "global",
    "location" : "Authorization",
    "locationType" : "header",
    "message" : "Invalid Credentials",
    "reason" : "authError"
  "message" : "Request had invalid authentication credentials. Expected OAuth 2 access token, login cookie or other valid authentication credential. See https://developers.google.com/identity/sign-in/web/devconsole-project.",
  "status" : "UNAUTHENTICATED"
Program Terminating
Translation FAILED.
I'm not sure why the authentication would be invalid while reading the data. Is there any workaround?
  • Apr 17, 2019 2:54 AM UTC
@jlutherthomas, do you have any suggestions?
  • Apr 22, 2019 11:26 PM UTC
Submitted a support case: C144571
