Get information from PostGis to CAD
  • August 29, 2018
  • 19 views
mr_fme
Forum|alt.badge.img+9
hi
I have some data DWG stored in PostGis Database, there is one attribute packed, created by AttributePacker, with all features of the layer, for example line_weight, color in the others. If I use AutoCAD to read Postgis Database, it´s possible to show the colors and the others features stored by AttributePacker automatically?
Thank´s
Forum|alt.badge.img+58
Probably not. And if so, you'll need to set that up on the CAD side, not FME.
