Generic Writer questions
  • May 14, 2013 2:16 PM UTC
  • 89 views
jhawks
Forum|alt.badge.img+7
When adding the Generic Writer into the Workspace I dont seem to be able to select multiple formats to write to. I can only pick one.
FME Desktop 2013 Build 13263
I have public web forms now but whichever format the user picks from the drop down menu it writes to shape. Because I only have Shape writers in the workspace. So I need to replace the Shape writer with Generic Writer and have it be able to write to shape, file gdb, dxf, dgn.
https://fmeserver.ncd.noaa.gov/encdirect_extract_approach.html
  • May 14, 2013 3:16 PM UTC
that is correct, you can only specify one output format in the Generic Writer. You could, however, publish the format as a public parameter, letting the users select the output format themselves.
The other strategy would be to have one dedicated Writer for each output format and using a Tester / TestFilter for route your features to the desired Writer, e.g. based on a published parameter.
David
jhawks
  • May 14, 2013 3:28 PM UTC
I have Generic Writer in the navigator and published the format as public parameter, but regardless of which format they select it writers to shape. If you use the generic writer a writer in the navigator, what do you use a writer in the workspace? See attached. http://ocs-gis.ncd.noaa.gov/encdirect_data/generic_writer.png
  • May 14, 2013 3:41 PM UTC
Which values have you tried passing to the published parameter "format"? An example would be helpful.
It also seems your workspace could be a case for dynamic schema. Take a look at this article by Mark Ireland for more details. Unless your input and output schema never changes, it could save you a lot of effort.
David
