GDB Writer is 'not set', how come and how to prevent?
fmelizard
Forum|alt.badge.img+20
I have a GDB with a road in it (themes are: road signs, traffic lights etc.). I have new measurements from the road in Shape (containing existing and new features). I have two GDB writers per theme: one to update the existing features, one to insert the new. The readers point to the same file and the writers point to the same copy of it.
After a while the Writers become '<not set>' in the Navigator pane:
Along with some translation warnings:
Geodatabase Error (-2147024894): The system cannot find the file specified.
Could not open File Geodatabase dataset `D:\\Data\\N207\\EXPORT_BUDATA_20160202_164111.gdb' for reading
The issue is resoved when the writer is deleted and loaded again but after a while the issue returns.
FME version is 2016.1, 32 bit.
@nielsgerrits
  • May 20, 2016
I have had the same issue with my work-spaces. Thanks for posting this.
mygis
Forum|alt.badge.img+14
  • July 4, 2016
Hi @camiel, could you try to use a different GDB for the reader and writer and see if this happens?
@camiel would you be able to send the workspace to support? What would be great would be if you could send a copy of the workspace before and after the problem occurred
