FME 2020: How to filter dwg file based on hatches and Areas (polylines)?
  • Nov 15, 2021 9:03 PM UTC
  • 150 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out how to filter dwg file based on hatches and Areas (polylines).
Clip_1134
Best answer by jkr_wrk
You can expose all kinds of autocad attributes. If you click on the feature you will see all attributes in the feature information window.
Like: autocad_entity_handle, autocad_frozen and autocad_entity
I guess the autocad_entity contains the type of autocad feature.
The geometry filter tells what kind of geometry it is: single point, multipoint, lines, closed lines etc.
jkr_wrk
Forum|alt.badge.img+37
  • Nov 15, 2021 10:08 PM UTC
jamal
  • Nov 16, 2021 8:09 PM UTC
Thank you for the help. It works fine
Clip_1136
