Filtering GPS points using polygon shapefiles!
aunoemer
Participant
I have one shapefilter consisting of agricultural land and some gps points in csv. how can I filter these gps points which fall in the agricultural land? I have already tried Spatial Filter but it doesn´t work all the time it fails. Would be really nice if anyone could help me with this problem. :)
danilo_fme
Forum|alt.badge.img+45
  • May 30, 2024
Hi @aunoemer
I suggest you to use the transformer PointOnAreaOverlayer for work with points(gps) and polygons(agricultural land).
andrewj74
  • May 30, 2024
use a vertex creator to plot the data first before using spatial filters. or ngr to xy converter depending on the format of your spatial coordinates in your csv
