External KML Style file
arnold_bijlsma
Forum|alt.badge.img+14
Has anybody ever tried to create an external Style.kml file that is being referenced by other KML/KMZ files? I have seen several blogs where the KML StyleMap is defined by creating a Style feature, and I've got that working fine. But I've got 500+ KML files (all regionalised etc.), and the result is that each of them has the same StyleMap definitions in the top of the KML. I would like to define all my Style definitions in a separate KML/KMZ file, and each KML file to reference just this file.
The Google KML documentation shows this is possible, and all you need is a line like this:
<styleUrl>style.kml#counties</styleUrl>
But how to get this in FME? I have been playing around with the kml_style_url_* and kml_target_style_* attributes, but have been unable to crack it, and there doesn't seem to be any documentation on all these kml_* attributes.
arnold_bijlsma
Here's a screenshot of my workbench. It reads a large GDB (not shown) containing 7.5million points and fans them out into 500+ KMZs, one for each UK Postcode District. The screenshot below has only read the first 10000 records, and created 3 KMZs. Each point is colored red, amber, yellow or green depending on a ModelRiskLevel parameter.
arnold_bijlsma
I think I may have cracked it. The trick is to have two Creator transformers: one creating the Styles using the KMLStyler transformer, and one creating the different StyleMaps using the kml_target_style_* attributes in an AttributeCreator. All outputs are then routed to a Styles.kmz
The big advantage of this approach is that if a user wants to have the styles changed (e.g. larger icons, different colors, labels switched on, etc.), all I'd need to do is send him a new 1kB Styles.kmz file (or the user can even manually edit it herself).
In the main workspace that creates all my 500+ KMZs, all I need is an AttributeCreator or AttributeManager and set
kml_style_url = Styles.kmz#myStyle@Value(ModelRiskLevel)_myStyleHighlight
See attached workspace createstyleskmz.fmwt and screenshot referencetostylefile.png
mark2atsafe
Forum|alt.badge.img+48
Good question - and great answer.
arnold_bijlsma
Thanks Mark. And the workspace looks a lot better with the new Junction transformer.
  • September 25, 2018
Hi Arnold, if you are still following this solution , I am unable to get something like this to work. Do you have a small complete example you could share. I agree the documentation is lamentable for this.
Thanks,
Ian
arnold_bijlsma
@ian2016: not sure what else I can share. The attached template file shows how to create a separate .kmz file containing all the style definition. Four styles are defined: Very High (red circle), High (amber circle), Medium (yellow circle) and Low (green circle). It also contains a blue circle as the highlight style. Those defined four styles and the highlight style are then applies to the kml_target_style_normal and kml_target_style_highlight attributes.
I have attached the styles.kmz file so you can look 'inside': styles.kmz
To create a KMZ file that references this styles.kmz, which is stored inside the same folder, you need the AttributeCreator as described in my answer.
There is also a bit about the balloon text, which has something to do with Extended Data and Simple Data. See https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/WKBkml/Extended_Data.htm
I am happy to share the full workbench on an individual basis, but I don't want to publish it on here. Just email me on arnold.bijlsma@stantec.com.
Thanks for your help Arnold, as usually happens, I got your approach to work with an example of my own while waiting for a reply from you. I am not at all familiar with kml and have been going round in circles with examples with the styles in the same kml, so that was most of the problem - confusion. Concatenating text to reference inside other files seems a bit weird to me but hey , if that's the way it works.
If I were to produce a single kml how would I use the Style URL to reference the styles within the same file? just take of the file name part on the attribute creator?
Thanks for your help.
Ian
arnold_bijlsma
  • September 26, 2018
Ian
If you only have a single KML/KMZ file, it doesn't make much sense to have a separate Styles file. In that case, it's much easier to define your styles inside that KML file by simply using the KMLStyler transformer.
