Export Arc SDE geodatabase to file geodatabase
  • Mar 2, 2015 11:05 AM UTC
  • 112 views
srinigis
Hi All,
I have a requirement where i should export the complete Arc SDE geodatabase to a new file geodatabase. This should be done using FME workbench.
Note : File Geodatabase should be generated newly on the fly and it should have all the subtype and domain definition as of ArcSDE geodatabase.
Kindly provide your inputs.
Thanks,
Srini
  • Mar 4, 2015 5:42 AM UTC
have u tried dynamic schema file geodatabase writer?
srinigis
  • Mar 20, 2015 9:30 AM UTC
Hi ,
I tried dynamic schema fgdb writer but , i have to add all featureclasses as reader to achieve it.
