Excel writer - overcome maximum row limit
  • November 8, 2016
  • 6 replies
  • 164 views
Hi, I have hit the maximum row limit for an excel spreadsheet with the excel output writer (1,048,576 rows).
Is there an easy option to overflow the rows into another spreadsheet?
Should I use a row counter and tester to overflow the data to another spreadsheet?
  • November 9, 2016
Hi @thiru, assuming that an attribute named "_count" contains the feature count number (0-based sequential number), this math expression returns 0-based index for each group of 1048576 rows.
@int(@Value(_count)/1048576)
I think you can configure destination feature type name (i.e. Excel sheet name) based on this value.
itay
Forum|alt.badge.img+17
  • November 9, 2016
Hi @thiru you can also do the following grouping:
Hope this helps.
groupfeatures.fmw
  • October 30, 2017
Hope this helps.
groupfeatures.fmw
Might need to divide "_count" with 1048575 to keep row limit under 1048576
  • September 19, 2019
How does it work exactly?
I have the same problem, and I'm not sure I understand where I'm supposed to plug this "groupfeatures".
I have 3 different writers, do I have to plug 3 "groupfeatures"?
How do I configure the writer to split into a new spreadsheet every 1 048 576 row?
Thanks
andreaatsafe
Forum|alt.badge.img+12
Thanks
Hi @thomas2,
The idea is that you would use the attribute that is created from the ExpressionEvaluator (eg _result) and use this in a feature type fanout for the Excel Spreadsheet name. This is how you would split the writer to split into an ew spreadsheet every 1 048 576 rows .
If you are writing out field names each time, you will want to divide by 1048575 to ensure the limit is not reached when writing the field names.
See the attached workspace which is a modified workspace for the one that @itay shared above. It includes the writer showing the fanout.
- Andrea
5516-groupfeatures.fmw
  • September 24, 2019
andreaatsafe wrote:
Hi @thomas2,
- Andrea
I think I understand how it works... thank you.
For the moment my FME is running with inspectors instead of writer just to check the validity of the final result.
I'll try your explanation on the next run.
