Equivalent of the ArcGIS "Update"
  • Jan 27, 2013 11:14 AM UTC
  • 41 views
Does anyone know what is the FME quivalent of the "Update" tool?
Thanks.
Pietro
davideagle
Forum|alt.badge.img+21
  • Jan 27, 2013 12:06 PM UTC
Assuming that you mean this: http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=Update%20(Analysis) ...then you will likely need a combination of Transformers to achieve the result you need. I'd suggest you take a look at the AreaOnAreaOverlayer in combination with the Dissolver. You'll need some usable feature IDs so if you don't have one use a Counter first as a substitute.
