Elastic Reader Issues
  • Jul 16, 2020 3:14 PM UTC
  • 31 replies
  • 327 views
Show first post
  • Nov 6, 2020 8:39 AM UTC
@miay did you add a new Elasticsearch Reader?
In the beta there should be a old Elasticsearch Reader (deprecated, supports versions 6.8 and lower) and a new Elasticsearch Reader (supports version 7+).
If it doesn't work, then we would definitely want to know. Do you have any logs or workspaces you can share?
Hi @jakemolnar​ & @bubblebeb​ ,
I've downloaded the new FME Desktop beta (build 21222) on Win64, and tried the Elastic reader (reading from an internal Elastic 7.9.1, both without and with a json query) and it seems to work!
Thanks @jakemolnar​ !
jakemolnar
@miay​  I'm glad I could help! 🙂
bubblebeb
  • Nov 6, 2020 5:04 PM UTC
Hi @jakemolnar​
I will check the indices with the my dev team. Hopefully it is just the set up here that can be updated.
Thanks
Seb
bubblebeb
  • Nov 24, 2020 6:39 PM UTC
Hi @jake​
I have sorted the connections now. Thanks for your help with that.
Is there a way of creating a query to pass to Elastic so I don't read in the whole index?
The index I am reading has over 2m features and is growing. Using a test I end up with 22k records I am interested in.
I would like to use a feature reader and a where clause but it is greyed out.
thanks
Seb
jakemolnar
Hi @jake​
thanks
Seb
Hi @bubblebeb​,
Glad to hear you've sorted out the connection issues!
You're in luck: that question has been asked before! https://community.safe.com/s/question/0D54Q000080heSCSAY/how-to-use-sql-like-commands-in-json-query-and-pass-it-through-fme-if-possible-using-httpcaller-elasticreader-and-featurereader
That answer pretty much just links you to our documentation here: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/elasticsearch/elasticsearch-ft-param-r.htm
  • Nov 24, 2020 8:51 PM UTC
Hi @bubblebeb​,
Hi @bubblebeb​  & @jakemolnar​ ,
We've tried to use a query, and that could look like this:
"query": {
"bool": {
"must": [
"match": {
"user": "the_username"
"match": {
"code": "200"
