DWG Writer - Raster - set img path as a proper relative path
jasperwis
Forum|alt.badge.img+15
Hi
I would like to add a raster to a DWG and have the path to this external reference set as a proper relative path.
When you write a raster to a DWG file, the AutoCAD writer automatically writes a PNG in the folder of your output DWG.
If you keep this PNG file next to your DWG, it will always open.
However, if you insert this drawing in a new drawing, the link to the image breaks.
This is caused by the path of the external reference (raster) that is not properly set a relative path.
If we look at the created path from FME in Autocad, we see this:
If you change the path type to relative in autocad
Then the saved path changes to:
I have tried to copy this in FME, but no effect:
Any ideas?
Jasper
AliAtSafe
Forum|alt.badge.img+23
  • July 22, 2024
Hello, @jasperwis.
Thanks for posting your question. I'm sorry you've been having issues setting a relative path for a raster. Before proceeding to troubleshoot your issue with a possible workaround, if you haven't already, there is a similar community post that asks about writing a raster with the DWG Writer. It's an older post, but it should provide some guidance. If it doesn't work out, I will be more than happy to delve into this.
Thanks!
jasperwis
  • July 23, 2024
Hi @AliAtSafe
I came across this older post earlier, but no solution to this problem.
I will ask our client for some more details and come back to this.
