DWG to Shape File workspace needed
  • Mar 26, 2020 2:30 PM UTC
  • 6 replies
  • 71 views
I need a workspace that will convert DWG to SHP. I get DWG files all the time and my Mapping software imports shape files. So I need shp files rather than DWG all ineed is the lines in the DWG not so much any data. I need help. I've tried different things with bad results.
  • Mar 26, 2020 2:37 PM UTC
It would be very helpful if you could tell us exactly what you've tried and what the results were, including why they didn't work for you.
I have the workspace and the dwg file I could share them both. The workspace translation runs fine no errors but I get nothing at the end. No lines. When running data inspector after the translation I get nothing.
  • Mar 26, 2020 2:45 PM UTC
Yes, the files would be helpful, I'm sure.
Fiber only subst.dwg
There's the DWG let me post the Workspace next.
AutoCAD_to_M4.fmw
