I want to set hatch layer fill colors which are defined by number values in the attribute “extended_data{1}.32Bit_integer{0}” (this option is not in the DWG styler), and I would like to edit the values of the data_list and extended_data attributes for a large number of map material that I am going to import.
Most of these DWG-attributes from CAD are removed during transformation. Is there a way to add, keep and set these attributes in FME? Directly adding them as user attributes did not get recognized in the writer.
The single “autocad_extended_data_list{}” is present as a format attribute but nothing else.
Best answer by gio
All the attributes are available on the dwg reader.
U need to expose them on the "format attributes" tab on the reader ( a large list)
U can also use an attributeexposer, this is particularily hadny if u are well known with the autocad format and can type in what u need by heart.
Very usefull in this respect is FME readers and writers bible "autocad" section.
This book explains what can and niot be done with the attributes.
Page 1 / 1
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
