Duplicate records from sqlexecutor
  • Nov 27, 2019 5:28 AM UTC
  • 5 replies
  • 115 views
Hi all
I have a simple IFC file which has just 8 IFCWalls and 2 IFCSpaces. When I run a simple query for retrieving all records for IFCSpace elements ( select * from "public"."IfcSpace"; ) , SQLExecutor duplicates all records. For instance, I have 2 records for IFCSpace but after running the query, I'll get 4 records. How can I avoid duplication? (I use PostGIS)
Best answer by oscard
The SQLExecutor has 2 features as input, so he transformer runs two times. That's why you have double the results.
Add a Sampler before the SQLExecuttor to get just one feature.
oscard
Forum|alt.badge.img+23
  • Nov 27, 2019 6:55 AM UTC
  • Nov 27, 2019 11:54 PM UTC
Thank you @oscard for your response, but I reckon you meant adding sampler after SQLExecutor, am I right? Anyway, it worked! Thanks.
oscard
  • Nov 28, 2019 6:50 AM UTC
It would work both ways, but adding the sampler before the SQLExecutor would mean less work for the database and less data to be processed by FME.
  • Dec 1, 2019 11:09 PM UTC
Can you please explain how do you do that? I mean I don't have duplication before SQLExecutor so, it would be again 2 records after using Sampler and then result would be 4 records.
oscard
  • Dec 2, 2019 7:06 AM UTC
Your SQL sentence in the SQLExecutor has zero dependency on attributes from the input (three is no where clause, for example); so the output is going to be always the same no matter the input.
You have 2 features that enter the SQLExecutor, so the SELECT sentence is executed twice. What you should do is filter the input to keep just one. That could be achieved using a Sampler (it is not a DuplicateRemover). To keep just the first feature:
