Does FME support autocad blocks that are dynamic?
  • Mar 6, 2014 2:34 PM UTC
  • 6 replies
  • 158 views
I am using the latest build of Fme desktop and I am trying to use an autocad block that has dynamic content in it and is not working. If I take the dynamic parts of it out it works just fine. Does anyone know if Fme supports Autocad dynamic blocks?
Best answer by mark2atsafe
As far as I know, we support reading dynamic blocks, but not writing. If there's a problem reading them I'd suggest getting in touch with the support team (http://safe.com/support). If you need to write them, also contact support and ask them to add you to PR#15958
I stumbled upon the same problem this week.
We are looking into the capabilities of FME to read dynamic properties within blocks and even read blocks within blocks but haven't found a solution so far. We even noticed that if you have a dynamic block FME doesn't store the original block name but the temporary block name that is generated by Autodesk Autocad when opening a dwg file with dynamic blocks. To provide interoperability this is a nightmare :)
We would love to see this in future releases because it would be an addition to our BIM Use implementation (Drawing Review) in our drawing offices.
mark2atsafe
Forum|alt.badge.img+59
  • Dec 3, 2015 8:06 PM UTC
Thanks for your reply Mark.
I managed to read all dynamic changes of our dynamic block library. Which is great!
It would be very interesting if we could reverse engineer that in the future.
nielsgerrits
Forum|alt.badge.img+67
Heya @Mark2AtSafe can you tell if this (resolving the original blockname of a dynamic block instead of *U123) is working in the current version? (2016 or 2017) Thnx!
mark2atsafe
Hi @nielsgerrits
That PR (writing dynamic blocks) is still open so it's not yet implemented. It doesn't seem to have a definite target either. Reading should be OK though.
nielsgerrits
Hi @nielsgerrits
Thanks @Mark2AtSafe I misunderstood then. I'm just looking for a way to read the dynamic block names. Could not get it to work today, do you have a pointer how I should be able to resolve them?
