Difference between MapInfo Writers?
  • Mar 21, 2024 11:29 PM UTC
  • 104 views
nicholas
Forum|alt.badge.img+14
Hello all,
I want to understand the difference between two MapInfo Writers
I am running FME Desktop version FME(R) 2022.1.3.0 (20220928 - Build 22630 - WIN64)
The Writers are;
MapInfo TAB (MITAB)
Precisely MapInfo TAB (MAPINFO)
Is one Writer better than the other?
j.botterill
Forum|alt.badge.img+69
  • Mar 22, 2024 2:28 AM UTC
Hi Nicholas, there are slight differences. Read rthis article on the pros/cons
https://community.safe.com/s/article/choosing-the-right-mapinfo-format
From the writer, there is the help documentation in the bottom left which should launch
Precisely MapInfo Extended TAB Reader/Writer (safe.com) support more file formats, >2GB tabs supported. If you want extended char length, use the extended tab reader/writer
Precisely MapInfo TAB (MAPINFO/MITAB) Reader/Writer (safe.com)
nicholas
  • Mar 22, 2024 4:08 AM UTC
One difference I have found is Character Encoding
MapInfo TAB (MITAB) allows you to set Character Encoding
Precisely MapInfo TAB (MAPINFO) does not
j.botterill
  • Mar 22, 2024 4:30 AM UTC
The MITAB seems to do long character string field lengths, but doesn’t support >2GB TAB files. If you need this, go to the Extended TAB reader/writer. You may also see a difference in how each handle the null case. There is a substitution of -9999 for null
