Mapinfo writer populating -9999 to empty integer records
  • Aug 16, 2017 5:07 AM UTC
  • 125 views
MapInfo writer is populating -9999 to attributes which have been manually set as integer or float and is empty. Cant figure out why?
Thanks,
Ashish
Best answer by david_r
Unfortunately the MapInfo format doesn't support NULL values.
FME will automatically substitute NULL values as follows when writing to a Mapinfo dataset:
  • NULL written to a numeric column becomes -9999
  • NULL written to string column becomes an empty string
You can use the NullAttributeMapper set to map to "New value" if you need other NULL substitutes.
mygis
Forum|alt.badge.img+14
  • Aug 16, 2017 6:04 AM UTC
Hi @ashish_m1,
Those values mean that there is no value which does not mean it is a zero. You can use the Tester transformer for a Null values and set them as zero, but this is not correct in my point of view. Otherwize just leave the -9999, other software should have the capability to ignore that specific -9999
I hope this helps.
Lyes
pratap
Forum|alt.badge.img+12
  • Aug 16, 2017 6:07 AM UTC
I think this is internal value of MapInfo. Pass "0" instead of null
  • Aug 16, 2017 11:38 AM UTC
  • Aug 16, 2017 1:21 PM UTC
Not sure using "0" is sensible as it could be a valid value whereas -9999 has some inferred value.
