Hi, I have to convert a .csv file to o .Las file.
csv to las
Best answer by takashi
If your CSV table contains x, y, z, and other point cloud components, consider using the Point Cloud XYZ reader to read the table as a point cloud feature. Once you read the table as a point cloud, you can then write it into a LAS file with the LAS writer.
