Create 3DTiles in WGS84 with unit in Radians
  • Aug 18, 2017 7:41 PM UTC
  • 117 views
I have a dataset with 3D buildings in the format CityGML (EPSG: 25832) and would like to present this in Cesium as 3DTiles. The 3DTiles must be available in the WGS84 with units in Radians, and at first the longitude and then the latitude must be listed. (See 3DTiles specification: https://github.com/AnalyticalGraphicsInc/3d-tiles#coordinate-system-and-units)
Input data:
Format: CityGML
EPSG: 25832,
Unit: metre
Geodetic CRS: ETRS89
Date: European Terrestrial Reference System 1989
Ellipsoid: GRS 1980
Example: 544913.83 5460346.67 205.41 (x, y, z)
Required output data:
Format: 3DTiles
EPSG: 4326 but in the unit radiant
Geodetic CRS: WGS 84
Date: World Geodetic System 1984
Ellipsoid: WGS 84
Prime meridian: Greenwich
Example: 0.1678606623,0.86034635,205.41 (longitude, latitude, height)
Here my experiments:
Reader: CityGML (EPSG 25832) -> Writer: 3DTiles (LL84-RADIANS)
Reader: CityGML (EPSG 25832) -> CSMapReprojector (25832 to LL84-RADIANS) -> Writer: 3DTiles (LL84-RADIANS)
Results: coordinates like this: 4109170.2188849915, 696274.18084379763
How do I create coordinates in radian unit?
Forum|alt.badge.img+63
Just quickly reading the specs and the way I interpret it the tiles can be any coordinate system you like and it's on the angles that are to be expressed in radians. But that's irrelevant if you're only doing buildings.
