Copying and renaming a folder to a different location
mackenziebudda
Participant
Forum|alt.badge.img+5
I'm pulling my hair out trying to get filecopy writer to work. What I want to do is copy a folder (and it's sub-folders) to a new location and to rename the copied folder. I'm using user-parameters to prompt for the new folder name but I can't get the file copy to work properly. I've combed through old forums but haven't found anything helpful. I think I can do the renaming with a system caller but I still cant get the filecopy to work... Any help is much appreciated.
I feel like this is fairly straight-forward, I'm still quite new to FME.
danilo_fme
Forum|alt.badge.img+49
  • June 15, 2020
Hi @mackenziebudda
In the attribute Destination Folder ( transformer AttributeCreator ) , please include:
Thanks in Advance,
Danilo
mackenziebudda
Participant
Hey @danilo_fme,
It worked! thanks for the help. The only thing now though is that it's not replacing the name of "new project template " with my @value(Project_WO_name). Instead it just creates a new folder with the @value(Project_WO_name) name and the "new project template" folder is nested inside.
Any suggestions?
jdh
Forum|alt.badge.img+33
  • June 15, 2020
mackenziebudda wrote:
Hey @danilo_fme,
Any suggestions?
if you want to change the name of the file, the new name must be stored in an attribute called filecopy_dest_filename.
mackenziebudda
Participant
@jdh I thought I'am doing that. I created the attribute called "Project_WO_name". This attribute is then passed to the filecopy writer.
jdh
  • June 15, 2020
Is filecopy_dest_dataset an absolute or relative path?
Is filecopy_source_dataset and individual file, or a folder? Does it contain wildcards?
mackenziebudda
Participant
@jdh
The filecopy_dest_dataset is an absolute path. I have an attribute creator going into the filecopy that sets that attribute as "U:\\2020\\..."
The attribute creator also sets the filecopy_source_dataset as "T:\\2020\\folder_template" where folder_template is a folder with a few empty sub-folders
jdh
  • June 15, 2020
If I understand correctly you have something like
T:\\2020\\folder_template\\subfolder\\etc.
you want
U:\\2020\\ProjectWO\\subfolder\\etc
but you are currently getting
U:\\2020\\ProjectWO\\folder_template\\subfolder\\etc
mackenziebudda
Participant
you want
@jdh Thats exactly what's happening
jdh
  • June 15, 2020
I don't have 2019 on this computer.
Can you try creating a fresh workspace with
A creator, attributecreator and fileCopy writer.
On the filecopyWriter set the Destination File Copy Folder to C:\\ (or a temp drive, it's irrelevant, but it will be created if it doesn't exist) and then unlink from user parameter.
Create the projectWO user parameter
The attributeCreator should have the following two attributes
filecopy_source_dataset: T:\\2020\\folder_template
filecopy_dest_dataset: U:\\2020\\$(Project_WO_name)
In FME 2020 that produces the correct results.
