Convert trajectory CSV to GPX from Mobile Mapper
I have a trajectory file with GPS time and coordinates from Mobile Mapper Ladybug camera and want to convert to .gpx file. The structure of .gpx seems to require quite a few additional attributes.
Anyone has any ideas or suggestions of how to process CSV?
Regards,
Maksym
Forum|alt.badge.img+56
When you read in the CSV file check out the Reader Parameters, you can specify columns to be lat/lon. That will automatically create the points.
GPX does indeed seem to require a lot of attributes, but is actually quite happy with a minimal set. You'll probably want to write your points as TrackPoints. Make sure to fill the track_id attribute (all with the same value) and then create a null geometry object, set the same track_id and write it to the Track feature type.
  • January 25, 2018
@mkhovalko If you attach a small example of your CSV, I'm sure someone will build a small example workspace for you.
abnan0001
Forum|alt.badge.img+8
  • February 25, 2021
Hello Everyone
Im trying to convert CSV to GPX format as data was collected using mobile mapping equipment..
When i have added as reader as CSV and writer as GPX , There are few parameters needs to be considered as i have X and Y to be linked as lat/lon in gpx ..
Kindly guide
Any Guidance highly appreciable
Thank u
