Convert SqlLite to SQL Server
Greetings.
I am trying to export a Sqllite (geopackage) to SQL Server.
Keep getting an error despite changing the options.
Reader:
Writer:
Error:
Transactions are being used by the Geodatabase Writer
An error occurred while attempting to open the table, feature class or relationship class 'main.airports'. The error number from ArcObjects is: '-2147467263'. The error message from ArcObjects is: {}
Stored 1 feature(s) to FME feature store file `C:\\Users\\User\\AppData\\Local\\Temp\\wb-cache-geopackage2mssql_spatial-NJVZFF\\Main_airports -1 10 -1 0 89fdbd78da335154a0ddf39d89823152eee47e98.ffsupdating'
Any suggestions??
Thanks,
Clive
  • August 20, 2019
Does the "main" table qualifier (usually it refers to a schema or a user) already exist in the geodatabase?
In SQLLite it is main.
In SQL Server it is dbo.
I get an error whatever I choose.
chrisatsafe
  • August 23, 2019
Hi @clives_online,
By any chance have you seen the answer on this post? It looks like they were getting the same error message and the issue was that it was not an SDE enabled database. Not sure if this is a new database or an existing one but it might be worthwhile to verify.
Hope this helps.
