Convert dgn7 to dgn7, text nodes changes to lines. Is there a way to remove these lines or to keep text node as is?
  • Oct 17, 2017 4:36 PM UTC
  • 75 views
erik_jan
Forum|alt.badge.img+26
  • Oct 17, 2017 4:41 PM UTC
It might have to do with the source format being equal to the destination format.
Could you try adding a BulkAttributeRemover before writing (expression igds*).
No guarantee, but it could help.
  • Oct 17, 2017 7:47 PM UTC
It doesn't seem to work.
erik_jan
  • Oct 17, 2017 7:54 PM UTC
Did you check the settings.
These are the default settings for some text features.
  • Oct 18, 2017 5:49 PM UTC
text in original file has text node with mslink number attached. when moving these texts to new file using FME, text node becomes a dot ( type = line).
