I'm calling a child Workspace using a WorkspaceRunner. The child Workspace says translation was successful as does the WorkspaceRunner, but when I reviewed the log for the child Workspace, I noticed there were warnings like this: "Provider error `(-2147217873) Violation of PRIMARY KEY constraint 'xxxx'. Cannot insert duplicate key in object 'yyyy'". If this happens, I want the Workspace to fail/terminate. Is there a way I can do this? Would a FeatureWriter transformer rather than a normal Writer give me this functionality?
Can I force a translation to fail if violation of a Primary Key occurs when writing to SQL Server?
- Sep 20, 2018 12:21 PM UTC
- 24 replies
- 198 views
- Sep 20, 2018 1:25 PM UTC
Which writer format is this? Pure SQL Server or is there some ArcSDE in the mix as well?
- Author
- Contributor
- Sep 20, 2018 1:33 PM UTC
- Sep 20, 2018 1:52 PM UTC
There's a little known trick to catching almost any message in the FME log and to act on it, using the fmeobjects.FMELogFile callback method.
Try putting the following in the Python startup script:
import fmeobjects
global AN_ERROR_OCCURRED
AN_ERROR_OCCURRED = None
def LogSkimmer(severity, text):
if text.find('Violation of PRIMARY KEY constraint') > -1:
AN_ERROR_OCCURRED = text
fmeobjects.FMELogFile().setCallBack(LogSkimmer)Then just before your SQL Server Spatial writer, insert a PythonCaller with the following code:
import fmeobjects
def detect_errors(feature):
if AN_ERROR_OCCURRED:
raise fmeobjects.FMEException(AN_ERROR_OCCURRED)Let me know how that works for your case.
- Author
- Contributor
- Sep 20, 2018 2:42 PM UTC
import fmeobjects
import fmeobjects
- Sep 20, 2018 2:46 PM UTC
- Contributor
- Sep 20, 2018 2:51 PM UTC
If you set the transaction to a number, larger than the number of records you are inserting, the transaction will be rolled back by any database failure.
The log file will contain the message, returned by the database.
I am 100% sure this is how it works for Oracle, and more than 99% sure it works the same for SQL Server.
Hope this helps.
- Author
- Contributor
- Author
- Contributor
- Sep 20, 2018 2:53 PM UTC
Hope this helps.
- Contributor
- Sep 20, 2018 3:07 PM UTC
Use a sql executor to get all constraints (usually at begin of your script) Process them and make your data respect the constraints before trying to write it to the table(s).
Here is a oracle sql version
select search_condition,table_name
from user_constraints
where table_name =
and constraint_type ='C'Choose the constraint type you require. You might need to access all_constraints in stead of the user_constraints
- Sep 20, 2018 3:13 PM UTC
where table_name =
- Author
- Contributor
- Sep 20, 2018 3:16 PM UTC
where table_name =
Your idea has got me thinking that I could put a DuplicateFilter in for the primary key attribute and connect the Duplicate port to a Terminator. The Python code option might make for a quicker translation though....
Plus the DuplicateFilter would only pick up features being processed, not conflicts with data already in the SQL table.
- Sep 20, 2018 3:40 PM UTC
- Author
- Contributor
- Sep 21, 2018 1:50 PM UTC
import fmeobjects
import fmeobjects
Also, it says 1 feature was written when it clearly wasn't.
2018-09-21 14:39:41| 4.0| 0.1|WARN |Microsoft SQL Server Spatial Writer: Failed to write a feature of type `yyyy' to the database. Provider error `(-2147217873) Violation of PRIMARY KEY constraint 'xxxx'. Cannot insert duplicate key in object 'yyyy'. The duplicate key value is (1234).'. SQL Command `DECLARE @WKB0 varbinary(max); SET @WKB0 = ?; DECLARE @SRID0 INTEGER; SET @SRID0 = ?; INSERT INTO yyyy ([field1], [field2], [etc]) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, CASE @WKB0 WHEN '' THEN NULL ELSE geometry::STGeomFromWKB(@WKB0,@SRID0) END)'
2018-09-21 14:39:41| 4.0| 0.0|ERROR |Microsoft SQL Server Spatial Writer: Failed to write a feature of type `yyyy' to the database. Provider error `(-2147217873) Violation of PRIMARY KEY constraint 'xxxx'. Cannot insert duplicate key in object 'yyyy'. The duplicate key value is (1234).'. SQL Command `DECLARE @WKB0 varbinary(max); SET @WKB0 = ?; DECLARE @SRID0 INTEGER; SET @SRID0 = ?; INSERT INTO yyyy ([field1], [field2], [etc]) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, CASE @WKB0 WHEN '' THEN NULL ELSE geometry::STGeomFromWKB(@WKB0,@SRID0) END)'
2018-09-21 14:39:41| 4.0| 0.0|ERROR |Error encountered while calling function `detect_errors'
2018-09-21 14:39:41| 4.0| 0.0|FATAL |PythonCaller(PythonFactory): PythonFactory failed to process feature
2018-09-21 14:39:41| 4.0| 0.0|ERROR |A fatal error has occurred. Check the logfile above for details
2018-09-21 14:39:41| 4.0| 0.0|INFORM|Microsoft SQL Server Spatial Writer: Closing `zzzz' . Write operation complete
2018-09-21 14:39:41| 4.0| 0.0|INFORM|=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2018-09-21 14:39:41| 4.0| 0.0|INFORM|Feature output statistics for `MSSQL_SPATIAL' writer using keyword `MSSQL_SPATIAL_2':
2018-09-21 14:39:41| 4.0| 0.0|STATS |=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2018-09-21 14:39:41| 4.0| 0.0|STATS | Features Written
2018-09-21 14:39:41| 4.0| 0.0|STATS |yyyy 1
2018-09-21 14:39:41| 4.0| 0.0|STATS |==============================================================================
2018-09-21 14:39:41| 4.0| 0.0|STATS |Total Features Written
- Sep 21, 2018 1:55 PM UTC
Since we're basically overriding the default FME termination behavior, I'm not too surprised that the "total features written" isn't quite correct.
- Sep 21, 2018 1:59 PM UTC
- Author
- Contributor
- Sep 21, 2018 2:03 PM UTC
A fatal error has occurred. Check the logfile above for details Program Terminating
Translation FAILED.
Regarding features written, it's not the overriding of FME behaviour that's the issue. If I run the translation without the Python, FME still says it's written the features, even though they all failed to write to the SQL Server table because of a Primary Key violation. I know we're talking semantics about what "written" means here, but I would argue that if it's not written, it's not written! I'm less decided about whether some features violating a Primary Key constraint but not others should constitute a successful or failed translation...
- Sep 21, 2018 2:07 PM UTC
Translation FAILED.
Out of curiosity, what happens if you use a FeatureWriter? Does the offending feature exit the <Rejected> port?
- Author
- Contributor
- Sep 21, 2018 2:21 PM UTC
Translation FAILED.
- Sep 21, 2018 2:27 PM UTC
- Author
- Contributor
- Sep 21, 2018 3:13 PM UTC
Translation FAILED.
- Author
- Contributor
- Oct 8, 2018 11:06 AM UTC
import fmeobjects
import fmeobjects
2018-10-08 11:58:17| 18.8| 0.0|INFORM|Optional `close' method not present; not called
I've looked this up and read a couple of forum topics about it but I'm not sure I completely understand what's going on. I assume it has something to do with the fact that a Writer is the end of a translation whereas the translation can continue after a FeatureWriter. It doesn't look as though anything bad is happening, but is there something I need to add to the Python script as best practice?
BTW, this is for a successful translation. I haven't yet tested whether Primary Key violations still terminate the translation.
- Oct 8, 2018 11:25 AM UTC
The log message seems to indicate that you have a class method that's missing the close() method. This is nothing to worry about, it's just for information. You can also get rid of the messge by adding the following method to your class definition:
def close(self):
pass- Author
- Contributor
- Oct 8, 2018 11:33 AM UTC
def close(self):
pass
- Oct 8, 2018 11:39 AM UTC
Regarding the line in the job log about the optional 'close' method not being present, you can safely ignore that.
Community Stats
- 33,015
- Posts
- 125,144
- Replies
- 41,980
- Members
