Can fme read whether a cell has comments or notes in an Excel xlsx document?
  • Dec 21, 2020 7:54 PM UTC
  • 7 replies
  • 206 views
jakethepainter
Forum|alt.badge.img+7
I have a giant spreadsheet that many people have added notes or comments to by right-clicking on the cell and saying "new comment" or "new note". Is there a way for fme to figure out which cells have comments?
debbiatsafe
Forum|alt.badge.img+24
Hi @jakethepainter​
There is an existing enhancement request for reading comments in an XLSX file using the Excel reader--this request is not planned at the moment.
Since XLSX files are zipped XML files, it is possible to unzip the XLSX file using FME and read the XML directly to get the comment cell values. I have attached an example of this approach.
Note: since the TempPathnameCreator transformer is used in the workspace, I would recommend not using Feature Caching when running the workspace.
I'm not familiar with Notes and it looks like the version of Excel I'm working with do not have the ability to create notes. But it looks like they are similar to comments so it may be possible to read them using the same method.
I hope this helps.
jakethepainter
Hi @debbiatsafe​  that is a great approach. I'm running 2019.2 right now and your feature reader won't load for me. Any chance you can just post a screen shot of the parameters?
debbiatsafe
Hi @jakethepainter​
This is how FeatureReader is configured in the workspace.
PathDir_FeatureReaderParameter
aurmax
  • Apr 24, 2024 5:32 PM UTC
@debbiatsafe Hello, I have a question on the topic. Can we reverse this process to be able to add notes back to the Excel file?
jkr_wrk
Forum|alt.badge.img+37
  • Apr 24, 2024 9:39 PM UTC
Yes, that could be done. But would not be very easy.
Use something to XMLUpdate the file that contains the notes and update the XML with your new Note. Write this new file to disk and then Zip all the original and new files into a file with the extention .xlsx
As long as you see an .xlsx file as a simple zip file containing xml files. And know how to read, write and edit xml files, you could test what changes are made to the file when notes are edited and replicate this behavior. And the result should again be a zip file containing xml files where .zip is replaced by .xlsx
aurmax
  • Sep 11, 2024 4:27 PM UTC
I fixed it. You need to install "openpyxl," a Python library for reading/writing Excel files.
Then use PythonCaller.
jkr_wrk
  • Sep 12, 2024 11:47 AM UTC
Thanks for sharing
