I have a 3D DGN file comprising of a building model, I wanted to convert it to ESRI Geodatabase without any geometry and attribute loss. I used "GeometryFilter" transformer however only lines and polygons are created without attribute information lost. Can multipatch geometry be created?? Is there a direct workflow available to achieve 100% conversion from DGN file to Geodatabase?? Please help me with the workflow. I can share a sample file if you can look into it.
Bentley 3D DGN TO Esri Geodatabase file conversion without geometry and attribute loss workflow??
