Autocad reader: get the version of a dwg file
  • Sep 28, 2020 8:16 AM UTC
  • 59 views
Skärmbild 2020-09-28 101536Hello,
I'm reading multi dwg files using dwg reader and need to get the version chossed when the user saved dwg file. i can see it in translation log when i run the reader but i couldn't get it as an attribute. any ideas or maybe transformator that i didn't find ´?
nielsgerrits
Forum|alt.badge.img+67
There might be a better solution, but when I needed this, I first read the directory scanning for the files, then read each DWG file using a text reader, only reading the first line and parsed the technical version from it. Then translated it using the table on Wikipedia.
  • Sep 28, 2020 9:59 AM UTC
I thought about the same way but didn't try it. do you have any workspace for this solution.
nielsgerrits
Here you go.
2020-09-28_12h22_57
  • Sep 28, 2020 12:09 PM UTC
you are the king I'll try it, thanx
