AutoCad DWG Reader Text Center / Bounding Box Incorrect
  • Feb 12, 2019 2:56 PM UTC
  • 5 replies
  • 121 views
Does anyone have a good way to extract the center point of a text string from DWG format?
In the past I've had very good luck in DGN format using a Bounding Box and Center Point Replacer.
However in these DWG's I have, the Bounding Box appears incorrect. In the image the problem is exaggerated, I believe Inspector is enlarging the texts compared tot he DWG size. The closest thing to the center point I've found is the upper right corner of the BB, but results are inconsistent, especially for text placed at an angle. Image shows text string, insertion point, BB calculated by Bounding Box Replacer, and the BB center.
jovitaatsafe
Forum|alt.badge.img+11
Hi @rl_gis,
This is what I'm getting when I try out something similar:
What version of FME are you currently using? 18578 is the build that I got this output with. Would it be possible to share a sample of your data and your workspace? It's odd that the center seems so off and that you would be getting inconsistent results.
  • Feb 13, 2019 10:01 PM UTC
Build 18586 Win 64
jovitaatsafe
Build 18586 Win 64
thanks @rl_gis! I'll try it out in the build as well. Would you be able to share your workspace and a sample of data? I can take a look and see if I can find a workaround for you that will output the correct center point.
  • Feb 14, 2019 2:19 AM UTC
Yes I will send you something through the report-a-problem page. BTW I queued up a simplified workspace in build 18552 Win32 and got a better result, but still appears off.
jovitaatsafe
Thanks for sending that in! I will look into it and get back to you soon.
