Add the 'Pound' symbol to a number format
  • Jan 29, 2018 3:10 PM UTC
  • 74 views
We are running FME desktop 2017 and are struggling to do a custom number format that will show the 'pound' symbol when writing to a new Excel sheet. shows a '?' symbol instead. the doller '$' works fine. We have changed the font to Arial and checked the character encode and it still wont display the £.
fmelizard
Forum|alt.badge.img+22
  • Jan 29, 2018 4:57 PM UTC
Hi @p80cey,
Thanks for reporting this. I tested this out and I see exactly what you mean. I did test this in the latest FME 2018.0 beta and it seems to be working there. Are you able to use the FME beta as a workaround? You can have more than one version of FME installed on your machine. Just be sure to install the new version into a seperate directory.
  • Jan 30, 2018 7:58 AM UTC
Hi @p80cey,
Thanks for testing and advising on 2018. The workbench will be run through Server 2017 so we would need to test that a 2018 workbench would run through Server 2017.
  • Jan 31, 2018 8:37 AM UTC
Hi @MattAtSafe,
Thanks again for getting back to me. Your example worked a treat! I feel such a nelly as I should have come to that conclusion myself.. your awesomeness has been noted, keep this up and you will soon be working the milkshake counter at Safe.
Thanks again.
