Does Connection Shape Affect Performance?
mark2atsafe
Forum|alt.badge.img+44
Does the shape of connection lines in FME Workbench have an effect on the performance of the workspace? You bet!
ALL PROOF IS in this video.
With square corners, the data is slowed when it reaches the corner. It can become bunched up and affect the performance of each transformer it passes through.
Curved lines have a similar effect, although not as severe because their corners aren't as sharp. However, they are longer lines, and so the data takes more time to pass through.
Straight lines have the benefit of being the shortest line and having no corners. As you'll see in the video, they are by far the best way to speed up your workspaces.
It's not mentioned, but also be careful not to cross connections. Features can collide at the crossing, knocking off some of their vertices or attributes.
geomancer
Forum|alt.badge.img+50
  • April 1, 2025
You made me start my day with a smile 😄
This is exactly why I’ve been in favor of straight connections all these years! Finally I am vindicated!
liamfez
Forum|alt.badge.img+35
  • April 1, 2025
Looks like I will have to leave my beloved curved connections behind and join ​@redgeographics’ camp.
@mark2atsafe  The amount of issues I have seen caused by crossing connections is killer, good to see it called out as many people wonder where their data runs off to.
philippeb
Forum|alt.badge.img+20
  • April 2, 2025
Just to make sure, was that an April fool’s day? 😅
liamfez
  • April 2, 2025
Maybe….
