SharepointOnlineConnector SingleTenant --- where to register TenantID
  • Jan 23, 2025 10:34 AM UTC
  • 62 views
hermann
Forum|alt.badge.img+11
Hei,
on the webside about
Troubleshooting SharePoint Web Connections and Services – FME Support Center
It says “If the application is single tenant then you should have the directory (tenant) id in the URL instead.”
Unfortunately, I can’t see where to find/change this URL. Where should I register the tenant ID?
Can somebody point me in the right direction?
Thank you.
Best answer by david_r
It’s under Tools / FME Options / Web connections / Manage services, then select your service.
  • Jan 23, 2025 12:04 PM UTC
