Hei,
on the webside about
Troubleshooting SharePoint Web Connections and Services – FME Support Center
It says “If the application is single tenant then you should have the directory (tenant) id in the URL instead.”
Unfortunately, I can’t see where to find/change this URL. Where should I register the tenant ID?
Can somebody point me in the right direction?
Thank you.
