I just tried this with FME 2017.1 (build 17722) and I can't seem to reproduce the issue. I've created a simple DWG using FME, set the writer parameter to AutoCAD Release 2013, checked that in Notepad, which showed AC1027, then read the file in FME again and it mentioned it being a Release2013.
So how exactly are you writing your AutoCAD file?
Did the same thing as you did. I write simple line as AutoCAD Object Data Release2013. Confirmed in Notepad.
I then read it with Inspector, says Release2018.
Version FME 2017.1.1.0 (Build 17650)
Hi @zzupljanin,
Sorry to join the conversation so late! I've just replied to your case and filed an issue in our tracking system as (FMEENGINE-62698) as I was able to reproduce the behavior using the RealDWG reader and the AutoCAD OD reader. I'll update this post as soon as the issue has been addressed. Thanks for reporting the issue!
