I would like to know how to set an emailer to a workspace from FME Workbench to send emails to a group of recipients once there is a status change.
  • January 14, 2021
  • 115 views
Forum|alt.badge.img+54
In short: the Emailer will send an email for every feature passing through, to the address(es) specified.
Within your workspace you need to set up whatever testing/checking for that status and once you found that route one feature to the Emailer. It will send an email for every feature (so make sure you don't inadvertently build a spambot...) and you'll need credentials for an outgoing (SMTP or Gmail) mailserver of course.
tomf
Forum|alt.badge.img+18
  • January 15, 2021
Note: to use multiple email addresses, use the comma ( , ) to sepearate them, not the semicolon ( ; )
