Get expiry time from FME Server API
  • January 20, 2021
  • 13 views
stefanh
Forum|alt.badge.img+8
Is it possible to retrieve the advanced information from Automations (like 'Queued Job Expiry Time' and 'Running Job Expiry Time') from the FME Server API?
I would like to automatically check if these options are used for all my automations.
Best answer by hollyatsafe
Hi @stefanh​
The FME Server Rest API endpoint for returning information about the components within a single Automation is unpublished, meaning it is subject to change without warning in new builds of FME Server so is not recommended for use.
Please consider upvoting this idea and add your supporting comments to request this endpoint be exposed.
  • January 20, 2021
Hi @stefanh​
