dwg writer getting feature that is not created
gisbradokla
Forum|alt.badge.img+17
I am using shapefiles to create multple attributes for dwg OD table output.
I have a dwg that does not have a feature for this output. (I am writing this to use in fme server). I use a tester to divert the shapefile feature out of the output stream. but the feature gets created in the dwg regardless.
I tried putting a NoFeatureTester to try to keep this from happening.
HOW does this feature get through the tester?
in the screenshot. the feature that is in the NoFeatureTester ends up in the dwg.
feature removed
tomfriedl
Forum|alt.badge.img+13
  • December 30, 2022
NoFeature​Tester:
Test if there ist incomming feature. If yes all features leave through the output port.​ Otherwise one new feature leave the NoFeature port.
gisbradokla
  • December 30, 2022
tomfriedl wrote:
NoFeature​Tester:
There are no features coming through. I put the no feature tester on there to see if I could detect why the feature is getting written. The feature is sneaking through somewhere
