Automation: email the result xlsx file with the dynamic name
  • Feb 23, 2024 1:34 PM UTC
  • 8 replies
  • 194 views
marias
Forum|alt.badge.img+11
Hello,
I have automation which triggers a workbench and has to send result file on email in the end.
The resulted excel file has dynamic name with @DateTimeNow parameter.
How to set that automation takes the correct file? If I add fixed name, it works fine but I don’t know how to make it for dynamic name. Could anyone help, please?
Best answer by nielsgerrits
Do you send the email using an Emailer transformer in the workspace? Then use a FeatureWriter to write the file and initiate the Emailer, and use the filename from the summary feature.
nielsgerrits
Forum|alt.badge.img+67
  • Feb 23, 2024 1:40 PM UTC
marias
  • Feb 23, 2024 2:01 PM UTC
Thanks for the reply. No, I use Action in the Automation itself:
marias
  • Feb 23, 2024 2:57 PM UTC
Thank you! I have adjusted my process using Emailer and set it to attach output _dataset and it works as expected.
nielsgerrits
The path to the file is in the dataset attribute.
  • Feb 23, 2024 3:06 PM UTC
You can use the Automation writer to send the filename from your workspace back to the automation:
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/automations/automations.htm
nielsgerrits
Thanks David learned something new today. I expected it to be possible but never used it myself.
marias
  • Jun 26, 2025 3:43 PM UTC
Hi, sorry, how from automation side find attributes from automation writer? I don’t see anything new using automation writer comparing with regular writer.
  • Jun 30, 2025 8:08 AM UTC
Hopefully this article can help: https://support.safe.com/hc/en-us/articles/25407765367053-Routing-Data-Between-Workspaces-in-Automations
