WFS Error
  • Apr 28, 2025 11:42 PM UTC
  • 76 views
vxn43
Forum|alt.badge.img+20
I am using the OGC WFS Reader to try and connect to my site in the TreePlotter App (cloud based app by PlanIT Geo). I have the API Key and other parameters.Β
When I run the Reader, I get these errors (from log file). Does anyone have an idea on what could be causing this? (I followed the instructions from their website:Β https://support.treeplotter.com/knowledge-base/wfs/)Β
2025-04-28 16:32:25| 0.8| 0.0|ERROR |<ows:ExceptionReport version="2.0.0=" xmlns:ows="http://www.opengis.net/ows/1.1=" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance=" xmlns:planit="planit:https://pg-cloud.com/planit=" xmlns:wfs="http://www.opengis.net/wfs/2.0=" xmlns:gml="http://www.opengis.net/gml/3.2=" schemaLocation="http://www.opengis.net/ows/1.1 http://schemas.opengis.net/ows/1.1.0/owsAll.xsd=">
<Exception exceptionCode="CODE WILL GO HERE=" locator="FeatureInPolygon">=">
<ExceptionText>https://pg-cloud.com</ExceptionText>
</Exception>
</ows:ExceptionReport>
2025-04-28 16:32:25| 0.8| 0.0|ERROR |Received error report: ExceptionReport
2025-04-28 16:32:25| 0.8| 0.0|ERROR |The XML Module halted on error, see the logfile for details
2025-04-28 16:32:25| 0.8| 0.0|ERROR |A fatal error has occurred. Check the logfile above for details
2025-04-28 16:32:25| 0.8| 0.0|ERROR |<WFS> An error occurred while reading a GetFeature response, to ignore the error and avoid losing the previously read features, set the WFS "Ignore GetFeature Error" parameter. Total features downloaded: '0'
Β
In the WFS Reader it appears I can connect to the site, I can see the layers:
Β
Best answer by birgit
If I see stuff like this my first thought would be that there is actually a problem on their side. Are you using a spatial filter? And can you maybe try to perform the getFeature call manually in the browser to check if it atually works outside of FME?
birgit
Forum|alt.badge.img+25
  • Apr 29, 2025 7:46 AM UTC
