Too many recursive macro substitutions
  • Aug 17, 2020 2:28 AM UTC
  • 376 views
keithhastings
Forum|alt.badge.img+14
I've got a big workspace (running on desktop 2019.1.1.0) that uses a few embedded custom transformers to perform some fairly complex calcs. I actually call one custom transformer a lot of times. This worked OK when I had about 75 of the transformers in the workspace, but now that I have about 90 it is returning the error "Too many recursive macro substitutions..."
I think there is probably a way I can use looping to physically reduce the number of transformers in the workspace, but this will be a very big effort and I'm not sure there is any guarantee it will actually fix the problem.
Has anyone seen this before and know what the issue is?
I have found a couple of unanswered questions about this when searching in the previous questions.
thanks
Keith
  • Aug 17, 2020 7:30 AM UTC
Have you tried converting the custom transformer from embedded to linked?
Also, do you do anything with e.g. Python inside the custom transformer?
