Terminator performs database rollback ?
lifalin2016
Forum|alt.badge.img+30
Hi list.
I've built a workspace with a loop looking for information, that I don't know the exact end of. So I loop with a margin, and I save an ID of the last found instance, and check whether I've had too many consecutive fails. If too many fails have been found, I redirect to a Terminator transformer.
However, when I ran the workspace, expecting some output to a database, no output was produced.
It seems that the Terminator transformer rollback previous database inserts. When I disabled the Terminator, all worked as expected.
Is there a way of making a peaceful halt of processing of a workspace, not the "pull-the-plug" kind of behaviour that Terminator seems to perform ?
I.e., is there an option to make the Terminator transformer less "Terminator"-like ??
Cheers
Best answer by david_r
Further to what @jdh​ says, since the Terminator only rolls back the currently open transaction block, it is possible to limit how much the Terminator rolls back by setting the writer transaction size to 1. That way you'll only lose the feature that triggered the Terminator, not the preceeding ones.
On the other hand, you'll notice that performance goes down because of the overhead associated with opening and closing that many transactions. But it's a technique that can be useful for debugging purposes.
jdh
Forum|alt.badge.img+28
  • October 23, 2020
How are you writing to the database? What is your features per transaction set to? Are you using bulk insert?
There's no "successful exit early" version of the terminator, but you can probably accomplish what you want by changing some of the writer parameters.
  • October 26, 2020
hkingsbury
Forum|alt.badge.img+55
  • October 26, 2020
Could you do something like this? The terminator will only fire once the FeatureWriter has written to the database. It will still fire even if the process doesnt produce any features to write
Screenshot 2020-10-27 094711
lifalin2016
  • October 27, 2020
Thanks David.
I hadn't thought about it being bulk, so yes, the transaction was never committed prior to the Terminator reeking havoc. Turning it off did the trick.
