Properly escaping string attribute values in custom Python transformer's setup dialog ?
  • Aug 17, 2018 9:41 AM UTC
  • 13 replies
  • 219 views
lifalin2016
Forum|alt.badge.img+42
Hi.
I've just built a custom Python based transformer, which utilizes two string attribute values.
One of the string had some embedded quotes ("), which were stripped before given to the Python code.
I tried swapping the quotes with single-quotes, but that crashed the Python execution entirely.
Is there really no automatic escaping of the entered values (into the transformer setup dialog) before passing them on ?
I managed to get it working by entering \\" (backslash-quote) in place of " (quote), but that's really a bad work-around. FME should really do that automagically by itself.
Cheers.
  • Aug 17, 2018 9:44 AM UTC
It's difficult to say without knowing more about how you're using the string attribute values.
Could you please post a sample workspace or some sample code that reproduces the issue?
lifalin2016
  • Aug 22, 2018 8:50 AM UTC
Sure. My transformer is included.
test-prependappend-transformer.fmwt
lifalin2016
  • Aug 22, 2018 8:53 AM UTC
The values in the transformer in the submitted template are escaped. Remove the backslashes to see the failure.
  • Aug 22, 2018 9:08 AM UTC
The linked custom transformer isn't available on my machine. You need to either post the transformer .fmx file here so I can install it, or embed the transformer into the workspace and repost.
lifalin2016
  • Aug 24, 2018 6:58 AM UTC
The transformer is included in the template. If this doesn't automatically make it available in the workspace, rename the .FMWT to .ZIP, and extract it from there.
  • Aug 24, 2018 7:34 AM UTC
Hi @lifalin2016, found the fmx, py files.
I think the following modification could resolve the problem.
  • In the fmx file, change the parameter type to "TEXT_ENCODED" if the parameter value could contain some special characters, such as double quotation.
  • In the Python script, decode the encoded parameter value with fmeobjects.FMESession.decodeFromFMEParsableText method.
lifalin2016
  • Aug 28, 2018 6:18 AM UTC
Hi Takashi.
Hmm, TEXT_ENCODED does not appear as a possible type in the docs about GUI-types !?
Is there another documentation to which only VIPs are privy ? :-)
Cheers
  • Aug 28, 2018 9:55 AM UTC
Please read the documentation more carefully. You would find the description like this.
_ENCODED.
This suffix means the value of the parameter will be WWJD encoded. ...
lifalin2016
  • Aug 29, 2018 1:06 PM UTC
_ENCODED.
Ah, I was concentrating on the left hand pane, not realizing that general suffix modifiers were defined. Thanks Takashi for sharing this insight.
What about the fmeobjects.FMESession.decodeFromFMEParsableText method ?
I can find it in the Python reference, but would never have looked for it under FMESession. What's the reason for it being "hidden" here ?
Cheers.
  • Aug 29, 2018 1:12 PM UTC
_ENCODED.
Here.
http://docs.safe.com/fme/html/fmepython/api/fmeobjects/_utilities/fmeobjects.FMESession.decodeFromFMEParsableText.html#fmeobjects.FMESession.decodeFromFMEParsableText
lifalin2016
  • Aug 29, 2018 1:33 PM UTC
_ENCODED.
FYI, the correct syntax is: fmeobjects.FMESession().decodeFromFMEParsableText(...)
lifalin2016
  • Sep 27, 2018 8:37 AM UTC
_ENCODED.
I cannot accept your answer, until you've entered it as one such, Takashi :-)
