Invalid scale reduction specified error when opening FME Desktop 2017.0
  • Feb 23, 2017 2:58 PM UTC
  • 73 views
mikel
I have just installed FME Desktop 2017.0 in OS X (El Capitan) and when I run FME Workbench, I get the following error:
Invalid scale reduction specified in coordinate system definition 'Calgary_3TM_WGS_1984_W114'
FME won't open
  • Feb 23, 2017 3:09 PM UTC
Sounds like a bug, please report it directly to Safe support with all the steps necessary to reproduce, if possible.
rylanatsafe
Forum|alt.badge.img+14
Hi @mikel, I'm sorry that you have run into this error! We recently had another customer contact Safe Support and discovered a temporary solution:
1. Open /Library/FME/2017.0/Reproject/LocalCoordSysDefs.fme in any text editor
2. Find the definition for Calgary_3TM_WGS_1984_W114 (~Line 264)
3. Change the SCL_RED value from 0.999900 to 1
4. Save the file and try opening FME Desktop again
*Please note that our Development Team is actively investigating. As @david_r suggested, please contact the and we will provide you with updates.
mikel
  • Feb 23, 2017 6:58 PM UTC
It works! Thank you.
rylanatsafe
This issue has been resolved for FME Desktop 2017.0 Build 17257 and Newer.
