how to set reader to start only after precedent procedures completed?
  • Jul 3, 2024 3:38 PM UTC
  • 116 views
chelseawu
Forum|alt.badge.img+19
Hello, I am working on a project which will fetch information and save to local machine, then I use xsd-driven-xml reader to read in the files to parse data down streams.
I noticed that reader activate before HTTPCaller task and caused the httpcaller failed to create file in the designated location. How to specify the reader to activate only if my HTTPCaller successful?
I have already have the tester set up and will be able to tell either failed or success, but xsd-driven-xml reader did not have condition parameter setting or anything for me to make sure it activate after tester passed.
I can separate this into two workspace, or create custermized transformer to encapsulate some condition tester and xml reader together, but thought there might be better way and would like to ask for help here.
Any information is appreciated.
Best answer by liamfez
You could use a FeatureReader, instead of a standard Reader, and connect it downstream of the HTTPCaller. That way the results of the HTTPCaller can be used to activate the FeatureReader. You could also add in some tests or filtering between the two if required.
chelseawu
  • Jul 3, 2024 3:52 PM UTC
actually customized reader transformer might not work after I thought through it…
May still need two separate workspace...
liamfez
Forum|alt.badge.img+44
  • Jul 3, 2024 5:09 PM UTC
chelseawu
  • Jul 3, 2024 5:28 PM UTC
Ha, you’re right!!!  This one works so much better than I use xsd-driven-xml reader directly..
Thank you so much!
