How to prevent CORS error when trying to do a POST to start an FME Server Job
  • Oct 7, 2019 11:06 PM UTC
  • 226 views
Good day,
I am trying to start a job on FME Server which works fine copy pasting the URL in a browser, in a Javascript application.
URL is like the following (some text replaced):
URL = "https://inspire-rather-wet-from-sweat.fmecloud.com/fmejobsubmitter/Tools/BetterWetfromSweat.fmw?SourceDataset_ARCGISFEATURES=https%3A%2F%2Fgisservices.noord-holland.nl%2Fagsp%2Frest%2Fservices%2FHosted%2Fbu_helsinki_knooppunten%2FFeatureServer&SourceDataset_ARCGISFEATURES_3=https%3A%2F%2Fgisservices.noord-holland.nl%2Fagsp%2Frest%2Fservices%2FHosted%2Fbu_helsinki_routes_snapped%2FFeatureServer&DestDataset_ARCGISPORTALFEATURES=https%3A%2F%2Fmaps.noord-holland.nl%2Fkaartenportaal&opt_showresult=false&opt_servicemode=sync&token=1234567890"
When I use this URL with in javascript, using the following snippet, I get a CORS error in Firefox and Chrome:
function startFmeServerJob(job_url) {
var xhr = new XMLHttpRequest();
var job_url = "https://inspire-rather-wet-from-sweat.fmecloud.com/fmejobsubmitter/Tools/BetterWetfromSweat.fmw?SourceDataset_ARCGISFEATURES=https%3A%2F%2Fgisservices.noord-holland.nl%2Fagsp%2Frest%2Fservices%2FHosted%2Fbu_helsinki_knooppunten%2FFeatureServer&SourceDataset_ARCGISFEATURES_3=https%3A%2F%2Fgisservices.noord-holland.nl%2Fagsp%2Frest%2Fservices%2FHosted%2Fbu_helsinki_routes_snapped%2FFeatureServer&DestDataset_ARCGISPORTALFEATURES=https%3A%2F%2Fmaps.noord-holland.nl%2Fkaartenportaal&opt_showresult=false&opt_servicemode=sync&token=1234567890"
xhr.open('POST', job_url, true);
//Send the proper header information along with the request
xhr.setRequestHeader('Access-Control-Allow-Origin', 'https://inspire-rather-wet-from-sweat.fmecloud.com');
xhr.onreadystatechange = function() {//Call a function when the state changes.
if(xhr.readyState == 4 && xhr.status == 200) {
alert(xhr.responseText);
xhr.send();
In FME server the following headers are allowed in the configuration part about CORS:
authorization, access-control-allow-origin, cookie, content-disposition, origin, x-requested-with, access-control-request-headers, content-type, access-control-request-method, cache-control, accept, Access-Control-Allow-Origin
The strange phenomenon was that the script did work in Internet Explorer, but not Chrome, Edge or Firefox.
I hope someone has an idea how fix the problem .
Kind regards,
Bart
Hi @bmonne,
I'm not an expert in this area but two things you could try to help fix this. In the FME Web UI please could you navigate to Admin >System Configuration>Networking:
  • Can you change Support Credentials to True - this allows the requestor to include credentials to authorize with the FME Server such as tokens.
  • Under the CORS settings please could you change the value for Allowed Origins from * to https://inspire-rather-wet-from-sweat.fmecloud.com. An asterisk cannot be specified if any credentials are being passed.
  • Oct 10, 2019 10:17 AM UTC
Thanks for the suggestions: it turned out something was wrong in the xhr header:
We changed:
to:
xhr.setRequestHeader('Content-Type', 'application/x-www-form-urlencoded');
And now it works fine.
Best regards,
Bart
