How to count FeatureWriter transformer's output into "Feature Written Summary" of the log?
  • Sep 29, 2017 9:45 PM UTC
  • 11 replies
  • 288 views
Hi! I have a FME workspace using FeatureWriter to write record to some tables. When running it from desktop, it populates the tables as expected. However, if I look at the log after job is completed, the "Features Written Summary" section at the end seem to be misleading by show "0", while I know that there are actually features written.
Do I need to do any change in my FME workspace to add the count to the summary? Thank you!
Below is the summary part of the log:
Below is the part of log for FeatureWriter, which does give the count:
danilo_fme
Forum|alt.badge.img+58
  • Sep 29, 2017 10:15 PM UTC
Hi @sui_huang,
I simulated here in my FME Desktop 2017 version and the log file was recorded the features created by transformer FeatureWriter.
The Log file has the first feature writer using the transformer FeatureWriter ( blue color in image )
The Information on LogFile Features Written Summary describe if you has a object Writer instead the Trasnformer FeatureWriter.
I believe that this information is in your LogFile position like my image attached.
Thanks,
Danilo
  • Sep 29, 2017 10:25 PM UTC
Hi @sui_huang,
Thanks,
Danilo
Hi @danilo_inovacao the log I got in FME 2016 is similar to yours. There is a separated part of the log showing the count for FeatureWriter transformer. I also think (as you said) that the summary count maybe only for the Writers but not the FeatureWriter transformer...if it is only run on my desktop I think I am ok with it.
However, when I posted the FME workspace to FME Server, the summary count will be highlighted in the job summary. I can only see the FeatureWriter counts only if I check log detail. This may cause confusion to other people managing the FME Server, so I post this question and hoping there is a solution to make things easier.
Essentially the issue roots from FME desktop, even though the FME Server will make the consequence bigger.
danilo_fme
  • Sep 29, 2017 10:40 PM UTC
Yes @sui_huang, i agree with you that it may cause confusion to read the written features on FME Server.
You can suggest an idea to an improved detailing of LogFile in FME Server :
Post New Idea
Thanks,
Danilo
fmelizard
Forum|alt.badge.img+22
  • Sep 30, 2017 9:35 PM UTC
Thanks for pointing this out. This is an oversight on our part and I can see how it might be misleading. We'll see how we can get some kind of statistical summary back into the logfile for a FeatureWriter situation.
danilo_fme
  • Sep 30, 2017 9:39 PM UTC
Thanks @daleatsafe to your reply.
FME always in constant evolution :)
  • Oct 2, 2017 2:50 PM UTC
@daleatsafe
Thank y
ou for responding so quickly. This makes me having a good faith that FME will keep being improved.
  • Dec 10, 2019 3:50 PM UTC
Hi @daleatsafe,
I see that this issue was raised in 2017, however, I'm currently working with v2019.0.2 and I am still facing the same issue.
Does this issue still stand unresolved or am I missing something? I see this issue on both FME Desktop and FME Server.
timboberoosky
Forum|alt.badge.img+7
Has there been any developments on this? I’m using 2024 and I still see the FeatureWriter(s) written summaries further up in the log file and not accounted for in the Total Features Written at the end of the log. The information is there but it would be helpful to be able to pull it all in at the end and be included in the overall summary.
kailinatsafe
Forum|alt.badge.img+24
Hello @timboberoosky, thanks for checking in with us. Unfortunately, there have not been any developments on this idea. Have you seen & upvoted the related FME Idea? Alternatively, you could try adding a logger transformer near the end of a workspace or a python shutdown script, that would present the total features written? This might not be worth the effort, but something to try. Sorry I don’t have better news, Kailin.
dustin
Forum|alt.badge.img+36
  • Sep 27, 2024 7:32 PM UTC
Along the same lines...if Redirect to Inspector is chosen it would be nice for FeatureWriter to honor that as well.
kailinatsafe
Hello @dustin, thank you for this feedback, I will make note of this & pass it along. All the best, Kailin
