Open
Include FeatureWriter counts in the "total features written" stats
Related products:Transformers
  • Jul 19, 2017 12:00 AM UTC
  • 15 replies
  • 262 views
Forum|alt.badge.img+63
As discussed in this q&a, output from the FeatureWriter is not included in the Total Features Written stat at the end of a workspace log and thus also not included in the job results page on FME Server. This can be confusing and potentially misleading so I'd like to suggest adding these numbers to the total.
  • Jul 20, 2017 2:11 PM UTC
Maybe do the same for FeatureReader too, unless it is already done.
  • Oct 20, 2017 10:14 AM UTC
Until it gets implemented, here's a workaround that outputs the feature counts of the FeatureWriters to the FME log and also makes it possible to use the feature counts in the shutdown script etc. using the standard mechanisms.
The solution basically consists of re-creating the same number of dummy features and do a fanout to the NULL writer. Since the dummy features contains no geometry and hardly any attributes, it shouldn't be too penalizing performance wise:
From the FME log after execution:
fmelizard
Forum|alt.badge.img+22
  • Oct 21, 2017 6:43 AM UTC
Love the ingenuity here. Don't love that you have to do this.
fmelizard
  • Oct 21, 2017 6:44 AM UTC
Very good point. Feature Reader needs same treatment.
  • Oct 23, 2017 6:34 AM UTC
Granted, I did have to take a shower after implementing that one.
mhab
Forum|alt.badge.img+10
  • Jun 26, 2018 8:25 AM UTC
I had to replace a reader by FeatureReader and need the statistics for the FeatureReader
fmelizard
  • Jun 27, 2018 4:53 PM UTC
Safe PR#63106
mhab
  • Jun 29, 2018 9:52 PM UTC
I uploaded a custom transformer to FME Hub which writes the Feature Read Summary to FME log file with same formatting as readers do, see: FeatureReadSummary_to_log_writer.fmx
see also: discussion in Knowledge Base
Screenshot of log file with the generated statistics:
aguan
Forum|alt.badge.img+11
  • Jan 29, 2019 4:04 PM UTC
Yes, the FME server report writer count should include both the counts from featurewritter and conventional writer.
davideagle
Forum|alt.badge.img+21
  • Jan 30, 2019 12:29 AM UTC
Whilst we're at it here, why not consider changing the wording of the message entirely? Instead of "Total Features Written", how about "Total Features sent to be Written"... It would make explaining why nothing has actually been written due to rejected features much simpler!
timboberoosky
Forum|alt.badge.img+7
Could really use some traction on this one after 5 years!
chriswilson
Forum|alt.badge.img+29
  • Sep 30, 2024 7:53 PM UTC
This does happen @timboberoosky, if you look back through the logs it produces a summary of features written for any FeatureWriter transformers in the workspace at the point at which they write their features.  Sometimes this can make it seem as though the process has completed, however there may still be other features to be written.  Often you end up with a few of these summaries in the log if you have a number of FeatureWriters in there.
See below, with my FeatureWriter_3 doing some early writing of features in a long process:
Grouping into an overall summary at the end - perhaps indicating which FeatureWriter or writer wrote however many features to whichever feature type - is probably the thing that is missing here.
timboberoosky
Maybe it’s just me but I can’t see the screenshots - could you post these again? I feel like this might really help but I can’t see it! Thanks!
LizAtSafe
Forum|alt.badge.img+26
  • Nov 21, 2025 10:47 PM UTC
Open→Gathering Interest
LizAtSafe
  • Nov 21, 2025 11:02 PM UTC
Gathering Interest→Open
