Handling hanging processes on FME Server - ABORT
  • Jan 8, 2020 10:48 AM UTC
  • 62 views
itsmatt
Forum|alt.badge.img+48
I'm looking for ideas to help me get around a problem with hanging FME Process. I've found (at least one case) where FME is hanging with a difficult geometry - I've tried a few things to fix the geometry, however, I haven't had much luck (I'm going to pass it on to support for them to look at).
The process is being called web API and it's expecting a response back when completed, either failed or successful - I am just using Fail topic to send back a response.
I decided to add in a 'tm_ttc' directive to make the job timeout instead of running forever. It works great, however, now the Failure topic isn't getting triggered and I can't let the tool know to wait for a response. It's the same when the job is canceled manually from the FME Server web ui.
Any ideas on this one?
Cheers
Best answer by itsmatt
Oh,
Looks like I just need to upgrade:
https://knowledge.safe.com/idea/76535/topic-on-cancel-1.html
Doh
itsmatt
  • Jan 8, 2020 10:50 AM UTC
Oh,
Doh
