group by and retaining none grouped data.
  • Sep 4, 2014 9:21 AM UTC
  • 69 views
This scenario has come about quite a few times already, but I have not been able to figure it out.
I have the following excel input data and want to produce the following output data. Please help me out using some Transformers. We are using FME Desktop 2013 SP2.
Sample input data (Reader)
First Name ¦ Surname ¦ Date ¦ Type
John ¦ Smith ¦ 01/05/2000 ¦ A
Joe ¦ Bloggs ¦ 01/01/2000 ¦ A
Joe ¦ Bloggs ¦ 10/05/2010 ¦ B
¦ means a new field.
Expected output data (Writer)
First Name ¦ Surname ¦ Dates ¦ Types
John ¦ Smith ¦ "01/05/2000" ¦ A
Joe ¦ Bloggs ¦ "01/01/2000" , "10/05/2010" ¦ "A" , "B"
Resulting Output.
I basically want to group some attributes to make unique names and then concatenate the remaining none-grouped attributes in turn into new attributes. Also need to consider that in the real input data there could be more than 2 people with the same name.
Thanks.
  • Sep 4, 2014 9:37 AM UTC
You can use the Aggregator to concatenate non-grouped attributes even if the features don't have geometry. Look at "Attributes to Concatenate" and "Separator Character" parameter of the transformer.
Takashi
  • Sep 4, 2014 10:45 AM UTC
Thank you Takashi.
I have tried the following settings and it doesn't work.
I have run with both Keep input attributes Yes/No and its not grouping or concatenating.
Out data stays the same as follows:
  • Sep 4, 2014 11:23 AM UTC
Check if the names (Joe Bloggs) are really identical including character case, white space etc.. Other transformers e.g. ListBuilder can group them?
  • Sep 4, 2014 1:32 PM UTC
Thank you very much for the help. All sorted.
