Geopackage "attempt to write a readonly database"
  • Oct 18, 2021 1:54 PM UTC
  • 7 replies
  • 372 views
After creating a simple Geopackage (one Table named '01004nnu') with the OGCGEOPACKAGE Writer with FME Desktop, I want to UPDATE Attributes in this Geopackage with a second workspace using the SQLExecutor.
Error message:
"OGCGEOPACKAGE reader: In ExecuteSQL(): sqlite3_step(UPDATE '01004nnu' SET col1 = '1' WHERE col1 = '8'):  attempt to write a readonly database"
The Geopackage ist not used by another process.
SELECT Statements do work with the SQLExecutor.
Forum|alt.badge.img+63
Can you doublecheck whether the file isn't accidentally set to read-only by the operating system?
  • Oct 18, 2021 5:10 PM UTC
Yes. File-properties are set on read/write
I tried using a fileServer and a virtual local disk.
After the first Error message there is another one I can not figure out what it could mean:
OGCGEOPACKAGE reader: Unable to read feature type '__fme_execute_sql_results__'
  • Oct 19, 2021 6:25 AM UTC
Here are two simplyfied FMW-files and their logs.
CREATEgpkg.fmw creates aGPKG named "aSmallGPKG.gpkg"
CHANGEgpkg.fmw wants to UPDATE an Attirbute Value "aSmallGPKG.gpkg" but fails reading the GPKG.
  • Oct 19, 2021 6:27 AM UTC
Sorry - only one file at the time.
should have zipped it.
arnovananrooij
Forum|alt.badge.img+5
@herfried​ Did you get this working? I'm trying to do the same thing and run into the same errors.
  • Mar 29, 2023 8:06 AM UTC
I did not. But i found a workaround so there was no need for the SQLExecutor anymore
jnknnn
  • Jul 19, 2023 12:33 PM UTC
I've run into same problem and can't figure out what's the problem...
